I & O editing in the trimmer
Posted by Gary & yvonne on August 8, 2006 at 8:55 amHow do I get back to the IN and Out selection editing in the trimmer. Thanks, Gary
Gary & yvonne replied 20 years ago 3 Members · 6 Replies -
Edward Troxel
August 8, 2006 at 1:12 pm -
Terry Esslinger
August 8, 2006 at 4:10 pmIf you do this, then you want to extend the end of the clip as a still (so as to add a transition in there) do you have to make a ‘still’ of the last frame and then add it. If you drag the end of the clip it just continues the clip from where you had trimmed it?
Edward Troxel
August 8, 2006 at 6:26 pm -
Terry Esslinger
August 8, 2006 at 7:38 pmThe problem is that I don’t want to extend the clip, I want to extend the last frame of the shortened clip as a still picture. I wish there was an easier way than ‘taking a picture’ of the last frame , adding it to the end of the clip and then adjusting its length.
Edward Troxel
August 8, 2006 at 8:25 pm -
Gary & yvonne
August 9, 2006 at 8:53 amMaybe i can’t get the in and out editing to work because i have looping on? When I click I for in….curser is there but doesn’t set it as a in point……it’s like the beginning of a looping.
Thanks for your reply. Gary
