Activity Forums Apple Final Cut Pro Legacy I need to upgrade my OS…..how do I collect ALL of the media & project files in FCP?
  • I need to upgrade my OS…..how do I collect ALL of the media & project files in FCP?
    Posted by Dave Sullivan on July 27, 2006 at 4:18 pm
    Hello all,
    I need to upgrade my OS to Tiger, and also upgrade to FCP 5 but I’m not sure what files I need to save so that my FCP projects will work when I load them back on my system.
    I know I need the project file, and the media files, are there any other files or folders I need to save?
    Any help would be gratefully received.
    All the best
    Dave
    Todd Gillespie replied 20 years, 1 month ago 2 Members · 4 Replies
  • Todd Gillespie
    July 27, 2006 at 4:49 pm
    Hi Dave,
    Apple make’s the transition very easy for you when you upgrade.
    Your FCP project files will update to FCP v5-so you might want to burn a copy of your project files before you upgrade and/or save the projects as a different file (leaving the original intact).
    If your media is on a Firewire Drive the drive will work fine, IF you are using a SCSI drive, then you might need to load new drivers with Tiger.
    The only thing that get’s me when I upgrade is my plug-ins. I use Boris Red for most of my titles, so I need to reinstall Red before I use FCP.
    Depending on the OS upgrade, if you use Archive and Install, you will have a copy of your plug-ins in the ‘old system’ folder. Most of the plug-in you can drag and drop into your new FCP plug-in folder. Just depends on the plug-in (if you even need to)
    Good Luck,
    Todd at UCSB
    Television Production
  • Dave Sullivan
    July 27, 2006 at 5:11 pm
    Hello Todd,
    Thank you so much for your reply. I really wish Apple would address the plug-in problem, but I suppose thats too much to wish for!!!
    Many thanks indeed for your help, I will put a post up when the upgrade has been completed…..without too many problems I hope!!!
    All the best
    Dave
  • Dave Sullivan
    July 31, 2006 at 12:36 am
    Hello Todd,
    Well all is well, I’ve upgraded to FCP and my OS, and touch wood all is well. My old projects open up OK……but the dreaded plug-in problem is still a pain.
    Many thanks again for all of your help.
    All the best
    Dave
  • Todd Gillespie
    July 31, 2006 at 5:42 pm
    Hi Dave,
    Glad to hear everything went well.
    Cheers,
    Todd at UCSB
