Activity › Forums › Panasonic Cameras › I need to transfer 720p60 29.97 to 59.94
Posted by Susie Smith on July 22, 2009 at 9:43 pmSo-
Our camera person shot 720p60 29.97 and everything I have Logged and transferred is in slow-mo. Yuck. I am trying to find a way to convert footage to 59.94fps playback. We have found a work around in after effects, but it only works for half the clip, then just freeze frames the 2nd half.
What to do?I don’t want to have to play at 200%ish speed in FCP and render every file!
-Susie
Jeremy Garchow replied 17 years, 2 months ago 2 Members · 9 Replies -
Jeremy Garchow
July 22, 2009 at 11:19 pmUncheck the option to ‘remove advanced pulldown/duplicate frames’ in the log and transfer preferences. It’s located in the menu that looks like a little gear on the L&T window.
Jeremy
Susie Smith
July 22, 2009 at 11:29 pmYeah, tried that first thing- doesn’t work. Footage isn’t getting “pulled-down” and isn’t duplicating frames. It has 60 frames that are playing back at 30fps.
Susie Smith
July 23, 2009 at 12:25 amyes indeed. audio actually isn’t important for this project, but i would like some way to batch convert footage if possible.
Jeremy Garchow
July 23, 2009 at 4:05 am[Susie Smith] “audio actually isn’t important for this project,”
OK, but is there audio attached to the clip? Just checking something.
[Susie Smith] “but i would like some way to batch convert footage if possible.”
Well, you can use Compressor to speed up the footage 50% then write a 60p file…Haven’t tested that but it might work. If you are willing to upload 2-3 seconds of material, I would be happy to come up with a recipe for you.
Jeremy
Susie Smith
July 23, 2009 at 4:45 pmI’m not sure about if any audio came in, but I think not. I’ll check.
I tried a couple different things in Compressor, but none of it seemed to work. The quick and dirty solution I’ve come up with is to put it in a timeline in FCP, put its speed to 200%, then export the clips.
We also tried to put it through AE. We set it to interpret at 60fps, then exported. This almost worked, except that half way through the clip it freeze frames.
Jeremy Garchow
July 24, 2009 at 1:02 pm[Susie Smith] “The quick and dirty solution I’ve come up with is to put it in a timeline in FCP, put its speed to 200%, then export the clips. “
Yes, that is what I was going to try as well. You can also do this in Compressor in a batch.
Audio on those clips?
Susie Smith
July 24, 2009 at 7:32 pmno audio.
What is the best way to do the batch export through Compressor? Select all the sped up clips in the timeline, then batch export thru compressor?
I was just going to select each clip separately from timeline, and export fat movie. -
Jeremy Garchow
July 25, 2009 at 3:27 pm[Susie Smith] “What is the best way to do the batch export through Compressor?”
I’d just take the raw files out of the capture scratch folder and bring them to compressor. In the frame controls tab you can then change the speed and reoutput to a new QT movie. I odn’ tknow how many you have, but I’d only setup about 30 files at a time, Compressor seems to choke on more than that. So you’d load up 30 files, apply your preset then hit submit. OPen Batch monitor and wait until you see Compressor start to work. At that point, you can then setup the next 30 files and submit them. Hope that makes sense.
Jeremy
