Activity Forums Apple Motion I need a stiff belt
  • I need a stiff belt
    Posted by Mark Suszko on February 19, 2010 at 5:00 pm
    In Motion 3, I’m using a canned animation in the content folder called “belt drive”. it looks like two gears connected by a toothed belt made of replicated squares. What I want to do is have the belt run as normal for two seconds, then slow to a stop. I tried throwing the clamp, stop and drag behaviors at it, but it keeps running like a Maytag washer. What did I screw up THIS time?
    Mark Spencer replied 16 years, 7 months ago 2 Members · 1 Reply
  • Mark Spencer
    February 19, 2010 at 5:04 pm
    Turn off the Rate Offset behavior on the belt and the Spin behaviors on the gears and use keyframes instead – on the Offset parameter for the belt, and on the Rotation parameter of each gear. You’ll have to manual set them so they match (In Motion 4 you could link them all together and control them all with one parameter).
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
