Activity Forums Apple Final Cut Pro Legacy I meant, Exporting from FCP5 for DVD SP4
  • I meant, Exporting from FCP5 for DVD SP4
    Posted by Christopher Bagnall on December 28, 2005 at 8:05 pm
    For some reason after upgrading to FCP5, I do not have the ability to export to MPEG2 for SP4. It seems to have less export options than before. Any idea as to why this happens and what I can do to fix this? Thanks
    Christopher Bagnall replied 20 years, 8 months ago 4 Members · 6 Replies
  • Dave Jenkins
    December 28, 2005 at 9:13 pm
    Your best bet is to export your sequence from FCP to Compressor via a reference file. It will compress faster than exprorting from FCP 5. However you can export to compressor from FCP 5 in the file-export.
    Dajen Productions
    Santa Barbara, CA
    G5 Dual 2 Gig – AJA IO & LA
    Huge 1.2 Raid
    FCP 5-OS X 10.4.1-QT 7
  • Steve Eisen
    December 28, 2005 at 9:39 pm
    You will also notice that you do not have A Pack. It now built into Compressor. If you are in desperate need of the MPEG Export, you can download it.
    There have been many posts regarding this change. You just have to change your work flow. Actually, you will like it because you can encode your video and continue to work in FCP.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Christopher Bagnall
    December 28, 2005 at 10:12 pm
    How would I create a reference file? Export using Quicktime? Thanks.
  • Gunleik Groven
    December 28, 2005 at 11:59 pm
    Just uncheck the “self contained movie” option in the export window, (after you have nested your sequence and mixed down audio and othervise readied your sequnce).
    Beware, the reference files are exactly that, so you may like to mixdown a selfcontained file for archieving and later use, if that is relevant.
    Gunleik
    December 30, 2005 at 11:17 pm
    What should my export setting be though? “Crrent Settings”?
    What should my export setting be though? “Current Settings”?
