Activity › Forums › Avid Media Composer › I like BIG bins and I can not lye…you other editors can’t deny.
  • I like BIG bins and I can not lye…you other editors can’t deny.
    Posted by Mike Cornett on March 17, 2009 at 1:23 pm
    I’ve come to inherit a project of a LARGE documentary. After combing over all the bins and looking the project over, it seems I have a problem!
    The bin with all the final sequences in it will not open. It’s a long error, but I get the feeling that it’s to big to open with the resource available.
    We just upgrade to the latest Media Composer software too.
    Any help would be great! Considering all I need to change is a few cg and and an end graphics…I really don’t want to rebuild this from scratch:)
    Mike Cornett replied 17 years, 6 months ago 4 Members · 5 Replies
  • Grinner Hester
    March 17, 2009 at 11:49 pm
    99 items in the bin on the wall, 99 items in the biiiiin.
    Take some out and pread it around, no more than 99 items in a bin or a waaaaall.
    thank you. I’ll be here all evening. don’t forget to tip your waitresses.
  • John Pale
    March 18, 2009 at 12:54 am
    Can you open it with your media drives unmounted?
    if so, move some of your sequences to a new bin.
  • Job Ter burg
    March 19, 2009 at 12:38 am
    You will need RAM. How much is in there?
  • Mike Cornett
    March 19, 2009 at 3:03 pm
    Thanks guys for the all the help. I had no idea about the 99 items in a bin rule!
    Anyway, it’s a RAM issue. The only time I can open the bin is when the Avid has been fired up the first time or on a restart. The bin in question has a file size of 180,665 K!
    I opened the bin, walked down the hall to refill my coffee, came back and then the bin opened:) It took a while to gather it’s brains:)
    There were about 12 duplicate sequences–all with different revised dates. The doc is a hour and it’s a pretty intensive doc. I moved half the sequences to a new bin. That helped.
    I finally just moved the one sequence I needed to a new bin and the bin file size is still like 30,000 K!
    I checked the computer and there is only 2.25 GBs of RAM!!!! I had no idea it was that small! I’m sending an email to our engineer (who originally speced it!) that we need to max the RAM out. I just assumed it was.
    I’ll update the thread if anything new arises.
    Thanks again for the help!
  • Mike Cornett
    March 19, 2009 at 3:10 pm
