Activity Forums Adobe After Effects I know this is not the correct place, but…
  • I know this is not the correct place, but…
    Posted by Fabiano Peres on July 29, 2006 at 4:25 pm
    Hi, I know I should go to an Encore community, but they couldn’t help me yet…
    people from this community are usually faster and better, so here I go.
    I’m trying to make a dvd with some pics and audio on the same track, the preview is OK, everything is perfect, but when I try to record it, thers is an error, “End of the strem has been reached”.
    What does it mean???
    What should I do???
    Thank for your priceless help.
    Fabiano Peres replied 20 years, 1 month ago 2 Members · 2 Replies
  • Mylenium
    July 29, 2006 at 5:01 pm
    Most likely one of your files is damaged and Encore can’t properly multiplex the streams. This wouldn’t show up in previews, only in the final project build when sectors are allocated to the data on the disc/ image file. Check your assets in external “dumb” programs like simple image viewers and audio tools (Winamp for instance). This would expose any damaged files either by not showing/ playing them at all or causing errors.
    Mylenium
    [Pour Myl
  • Fabiano Peres
    July 31, 2006 at 11:56 am
    Thanks for the answer, but all my files work well out of Encore. I really don’t understand it.
