Activity Forums VEGAS Pro I know how to do picture in picture, but what about zoomed picture in picture?
  • I know how to do picture in picture, but what about zoomed picture in picture?
    Posted by Joshua Porter on March 28, 2013 at 10:12 pm
    Hello, creating the PIP effect is simple enough. I just go into Pan/Crop and make the box with the F much larger than the video then drag it to where I need it to be. But in this case, I need my little picture to not be the entire video, but a zoomed in (same aspect ratio) piece of that video which is not possible using the method I know now. Can anyone give me a tip on how to accomplish this? I’m not quite sure what to search in a search engine so I haven’t found anything helpful yet. Thank you.
    John Rofrano replied 13 years, 5 months ago 3 Members · 2 Replies
  • Tyson Onaga
    March 29, 2013 at 1:20 am
    You should use Track Motion (and not Pan/Crop) to position your events to get the PIP effect. You can then use Pan/Crop to move about the media while the clip stays fixed. Or, you could animate the clip positioning via Track Motion keyframes.
  • John Rofrano
    March 29, 2013 at 11:16 am
    Tyson is right. You should be making the Picture-in-Picture with Track Motion and resizing the frame with Pan/Crop.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
