Activity › Forums › Apple Final Cut Pro Legacy › I know drop shadow is broken… but edge feather too?
  • I know drop shadow is broken… but edge feather too?
    Posted by Nick Ryan on December 12, 2006 at 8:50 pm
    So we all know that if you apply a drop shadow to a graphic it may or may not come out clean. There’s a good chance it’ll cause your image to jump around quite a bit. I ran into this again today and thought “Oh yeah, the drop shadow doesn’t work. Well, I’ll work around it and make a drop shadow with a slug.” So, I made a slug, cropped, feathered, with 50% opacity and put it between the graphic and the background.
    My new discovery: the moment you change the edge feather setting under the crop controls on whatever layer you have underneath your graphic, you wind up with the same effect as if you had used a drop shadow: a jittery graphic.
    Frustrating.
    Any thoughts?
    Nick
    Rich Campbell replied 19 years, 9 months ago 4 Members · 6 Replies
  • Doug Olin
    December 12, 2006 at 9:08 pm
    Have you tried adding the drop shadow in Boris Red and then using that graphic and drop shadow combo? I don’t have the problem with drop shadows producing jumpy video but using Red might be a work around for your problem.
    Doug Olin
    Desert Vistas Multimedia
  • Nick Ryan
    December 12, 2006 at 9:30 pm
    I can give it a shot – I’m trying a workaround with Photoshop at the moment… we’ll get it one way or the other.
    Thanks for the response!
    Nick
  • Doug Olin
    December 12, 2006 at 9:38 pm
    Photoshop will allow you to add a drop shadow of whatever type you want. The only problem with that solution is that you need to go back to Photoshop to make any adjustments in the drop shadow for depth, softness, etc. Using Boris Red would allow you to interactively change the drop shadow while viewing the result. It’s not as good as being able to change the drop shadow in FCP but it seems to be better than creating the shadow in Photoshop.
    BTW, did you ever get the dropped frames problem sorted out with Medea?
    Doug Olin
    Doug Olin
  • Chris Borjis
    December 12, 2006 at 10:59 pm
    dang, apple needs to fix these little problems or disable these options altogether.
    who needs crappy looking effects of any kind?
  • Nick Ryan
    December 13, 2006 at 6:53 pm
    Ahh, ok, I see your point. That makes sense.
    Dropped frames? Do you mean the flashing pixels/lines problem? No, we never did get that solved. I’ve e-mailed Medea a couple of times and they are silent to me. I’m thinking of calling ATTO, but haven’t done it yet. We did make a rather big discovery the other day, the flashing pixels are introduced into the video even when merely copying the file from the Medea to an external drive. From that point on they’re permanent, of course.
    Nick
  • Rich Campbell
    December 13, 2006 at 9:57 pm
    This is Rich with Medea Support. You can try richard_campbell@avid.com. Call me at 818 880 0303 ext 122 or email me a time and number so I can call you. Either way I would need some more info to attack the issue with respect to the Medea. Look forward to hearing from you.
    Regards,
    Rich Campbell
    Technical Support
