Activity Forums DaVinci Resolve I just updated to DR Studio 16 – OFX are disabled?
  • I just updated to DR Studio 16 – OFX are disabled?
    Posted by Don Cobble on August 12, 2019 at 9:56 pm
    I just updated to the final studio 16 version and am getting this message? “OFX Plugins have been disabled due to an error when loading”
    It appears to be common, but I have not found an answer? Can anyone point me in the correct direction,please
    Thank You
    PC 1
    I7 7820K 3.6Ghz
    16 GB Ram
    SSD 850 Pro OS drive
    2x 850 EVO Raid 1TB
    Win 10 Pro 64bit OS
    WX 7100 8GB
    Don Cobble replied 7 years ago 2 Members · 2 Replies
  • Tero Ahlfors
    August 14, 2019 at 12:16 pm
    This happens if you have an OFX plugin that’s not working properly. Usually it might be an older plugin that doesn’t work on newer applications or there’s some other compatibility issue. You should be able to add more plugins if you just go to the OFX page but if this keeps happening you might have a faulty plugin that’s not compatible with Resolve.
  • Don Cobble
    August 16, 2019 at 1:38 pm
    Tero,
    Thank you for reply. is there a method for identifying the plugin that you know of?
    or just trial and error?
    When i do find it or them, is there a way to disable them for davinchi only, so they do not affect my other programs or will I have to lose them?
    Thank You
    Don
