Activity › Forums › VEGAS Pro › I imported a veg done on V4 into V6…
  • I imported a veg done on V4 into V6…
    Posted by Randall3 on June 9, 2005 at 6:25 pm
    and here is the problem – an error message comes up that V6 cannot find the audio plug-ins that were used on most of the audio. What gives? Anyone have an idea how I can fix this. The upgrade apparently zapped V4 off my puter for good.
    Randall3 replied 21 years, 3 months ago 5 Members · 11 Replies
  • 11 Replies
  • Edward Troxel
    June 9, 2005 at 7:54 pm
    The names changed from “Sonic Foundry” to “Sony” between those two versions.
    Edward Troxel
    JETDV Scripts
  • Randall3
    June 9, 2005 at 8:13 pm
    The names changed…you mean file names – pretty dumb upgrade then. I had 4e which did change (or thought it did) everything to Sony. Has this happened to you as well?
  • Edward Troxel
    June 9, 2005 at 9:13 pm
    I was just taking a stab. If you go to add an effect in Vegas 4 (even 4e) you’ll see the effect names begin with “Sonic Foundry” while in 5 and 6 they begin with “Sony”. Can’t say for sure that’s the reason, was just throwing out a possibility.
    Edward Troxel
    JETDV Scripts
  • Gary Barrett
    June 9, 2005 at 11:23 pm
    Audio track defaults in earlier versions, [EQ gate compressor] are not auto insterted into channels any longer. This seemed to be the only changes for me.
  • Peter Wright
    June 10, 2005 at 1:06 am
    The three auto inserted audio FX are all there on my 6.0b. If they are not on yours, try adding them manually then right click on track header and select “Set Default Track Properties”.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Gary Barrett
    June 10, 2005 at 1:17 am
    I wasn’t missing the feature. V6.0b does not load any audio track fx by default for me.
    I prefer it that way.
  • Donatello
    June 10, 2005 at 2:16 pm
    the V6 upgrade should not zap V2,V3,V4,V5 off your hard drive ..
    you should find V4 on your drive = C:program filessonic foundryVegas4 … i still have all the old versions on one of my computers … and on 3 other computers i keep V3-V6 ..
  • Edward Troxel
    June 10, 2005 at 2:43 pm
    Oops, I missed that part. The Vegas 6 install will not touch Vegas 4. I too have a machine with Vegas 4, Vegas 5, and Vegas 6 all installed and all working.
    Edward Troxel
    JETDV Scripts
  • Randall3
    June 10, 2005 at 2:44 pm
    The download upgrade did remove V4 off my puter. Strange.
  • Edward Troxel
    June 10, 2005 at 4:46 pm
    I don’t see how that is possible unless you MANUALLY chose the install location and chose where Vegas 4 was installed.
    Edward Troxel
    JETDV Scripts
