Activity › Forums › Adobe Premiere Pro › i have i5 system can i use permier cs5.5 !!
Posted by Kumar Das on September 30, 2012 at 12:56 pmi have i5 system can i use permier cs5.5
Walter Soyka replied 13 years, 11 months ago 2 Members · 7 Replies -
Walter Soyka
September 30, 2012 at 2:00 pmHave you seen the Premiere Pro CS5.5 system requirements [link]?
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Kumar Das
September 30, 2012 at 2:31 pmya..but when i run avchd file on permier per cs5.5 it;s run very slow..
Walter Soyka
September 30, 2012 at 3:08 pm[kumar das] “ya..but when i run avchd file on permier per cs5.5 it;s run very slow..”
Well, that’s a rather different question…
AVCHD decode is pretty computationally expensive. It’s doable on a fast system, but on a slower system like yours, I’d consider transcoding to an intermediate format like CineForm, DNxHD, or ProRes.
Walter Soyka
Kumar Das
September 30, 2012 at 5:06 pmMy system info–
Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz
14.0 GB Ram
ATI Radeon HD 5450 ( Graphic Card )
Can i edit Avchd File in this pc..or how can i edit or what shroud i do for edit avchd file…in my pc..
Walter Soyka
October 1, 2012 at 1:20 pm[kumar das] “Can i edit Avchd File in this pc..or how can i edit or what shroud i do for edit avchd file…in my pc..”
Your computer may be too slow for responsive AVCHD editorial.
Transcode your AVCHD footage to an intermediate format, like CineForm, DNxHD, or ProRes.
These formats take up more disk space, but require less CPU power to decode. They should provide a smoother editing experience than native AVCHD.
Walter Soyka
Kumar Das
October 4, 2012 at 1:14 amDear Sir,
Is the Zotac graphics cards come with mercury playback engine!!!
Bcoz I want to use in Adobe premiere pro cs5.5.& Adobe Premiere Pro cs
5.5 or cs6 support only mercury playback engine !! plz Reply As soon
as Possible.. -
Walter Soyka
October 4, 2012 at 9:09 pm[kumar das] “Is the Zotac graphics cards come with mercury playback engine!!! Bcoz I want to use in Adobe premiere pro cs5.5.& Adobe Premiere Pro cs 5.5 or cs6 support only mercury playback engine !! plz Reply As soon as Possible..”
The Mercury Playback Engine has a software-only mode for systems that do not have a compatible graphics card.
Mercury Playback Engine, with a compatible CUDA or OpenCL GPU, can be hardware accelerated. This will help with the processing of transforms and effects, but it will not help with decoding AVCHD. In other words, adding an MPE-approved GPU may not give you the performance boost I assume you’re looking for.
The list of approved GPUs is with the system requirements [link].
Walter Soyka
