Activity › Forums › Maxon Cinema 4D › I have a very complex image I need to make 3d and color…I cant figure out what I am doing wrong.
Brian Jones replied 13 years, 11 months ago 2 Members · 26 Replies
Raf Erosa
September 13, 2012 at 9:40 pm -
Raf Erosa
September 13, 2012 at 10:29 pmThis what I ended up with when I smoothed out the edges. It now fills in the body and not the borders. How can I fix that?
Here is the C$D project file: https://www.box.com/s/ha0yrm13r1x2oodts84r
Here is the AI path file:
https://www.box.com/s/0aqhch4incn87byxttyiI really need a solution for this. I feeling kinda down about it. 2 days of working on this, and I cant get it right. 🙁
Raf Erosa
September 14, 2012 at 12:55 am -
Brian Jones
September 14, 2012 at 3:56 amThe C4D file is real close but has some extra points in some places and the structure is not right yet. I did a quick video because it’s easier to just show you rather than write it.
I keep using Optimize in the video by right-clicking – it’s not there in the right-click contextual menu for splines by default in 14 but I added it using Window/Customizations/Customize Menus you can access Optimize in the Mesh/Commands menu.https://reels.creativecow.net/film/mayasplineclean
Raf Erosa
September 14, 2012 at 7:01 amhow do i fix the splines that have the small loops.. They seem to be twists, and when untwisted, the ruin the other parts of the nurbs. How do I edit it, replace it or fix it?
Brian Jones
September 14, 2012 at 1:42 pmselect both points – Live Select tool with Only Select Visible Elements unchecked – and use the Weld Tool (Mesh/Create Tools M-Q is the shortcut)
Raf Erosa
September 14, 2012 at 2:33 pmOk.. The small bezier loops are not being romoved with “Optimize”…
How do fix those small loops if the Optimization doesnt work? -
Raf Erosa
September 14, 2012 at 3:22 pm
