Activity Forums Adobe After Effects I have a question about masks
  • I have a question about masks
    Posted by Jeremy Lee on May 1, 2006 at 8:39 pm
    I am watching the 2nd DVD set of Total Trainings AE 6.5 and I am not having any luck with the mask project that Steve H teachs. The effect is suppose to be like a spotlight that moves from side to side. The trouble I am having has to do with being able to move the inverted mask around to the next position. What happen was I first made an adjustment layer, moved it above a brick wall layer the mask will move over, using the oval mask I made a cirle then inverted it to reveal the brick wall layer, if I move the mask the entire adjustment layer moves and you see my oval and the surrounding edge of the layer instead of just seeing the oval move. I have this feeling it is something simple, but I just now learning AE and I don’t know that much about this program. I did click on the stopwatch for Mask shape and the only thing that I seem to be able to move is the entire layer instead of only the mask.
    The effect I get is the adjustment level moving with the inverted mask.
    Please somebody help me.
    JDL
    Jeremy Lee replied 20 years, 4 months ago 2 Members · 2 Replies
  • Soccer12
    May 2, 2006 at 5:58 am
    make sure you have the mask selected and not the layer…
  • Jeremy Lee
    May 2, 2006 at 3:33 pm
    That was it. I was driving myself crazy because I was double clicking and loading the layer in the the c window and any ways I carefully selected the mask and it worked.
    Thanks a million.
    JDL
