Activity › Forums › Adobe Premiere Pro › I have a problem
I have a problem
Posted by Gil Sabag on November 30, 2010 at 1:23 pmI’m Trying to open ppro cs4 and whil it does all of it’s file loading it get stuck loading a file called SHARPEN.AEX and it dosn’t move,and I have projects to finish,I don’t no what to do or what is that file,any ideas?Thanks, Gil.
Adam Prest replied 15 years, 9 months ago 4 Members · 5 Replies -
Richard Van den boogaard
November 30, 2010 at 2:22 pmI believe AEX is a plugin file. Go to your plugins folder (or Common, do a search for it), move or rename that file and see if PPro now starts.
Richard van den Boogaard
Freelance cameraman • Glidecam Operator • Editor • YouTube expert -
Tim Kolb
November 30, 2010 at 5:11 pmRichard is correct.
In the short term, you could yank out that fx pluginand see if you can start.
You may also consider reinstalling After Effects, as there may be some problems there. An AE reinstall should fix that plugin.
TimK,
Director, Consultant
Kolb Productions, -
Gil Sabag
November 30, 2010 at 6:28 pmI’v tried to delet/modify the file,didn’t work. So what u saying is that this is an AE file that preventing the premiere from loading?
Tim Kolb
November 30, 2010 at 9:14 pmDid you find the Common folder? There are certain effects that are installed with AE, but are shared between AE and PPro through the Media Core…
Some of the effects installed with Premiere Pro are actually AE effects however… I wonder if this one is in PPro’s plugin folder?
TimK,
Kolb Productions, -
Adam Prest
December 1, 2010 at 4:43 amfind the file sharpen.aex and move (not copy) move it to a temporary folder or to your desktop. then try starting premiere pro again and let me know.
