Activity › Forums › RE:Vision Effects › I have a problem with twixtor’s plugin on my interlaced AVCHD
  • I have a problem with twixtor’s plugin on my interlaced AVCHD
    Posted by Yong jin Lam on February 17, 2011 at 2:12 pm
    HELP!!!! See the video below…
    https://www.vimeo.com/20059848
    I just don’t understand why this weird stuttery effect on that’s guy’s jacket happen, and if u notice, the hands’ movement are also abit jerky… I tried deinterlacing the avchd already using fieldskit deinterlacer, set to 1frame per frame to no avail… HELP PLEASE!!! Please give me a step-by-step as to how i can do it…
    Yong jin Lam replied 15 years, 7 months ago 2 Members · 2 Replies
  • Peter Litwinowicz
    February 17, 2011 at 9:09 pm
    You are just hitting a problem with optical flow retiming. The jacket is moving fast and changing shape, and is crossing against a background… and this is problematic for software that retimes by only “seeing” in 2D.
    If you read the manual that was installed with the plugin, you’ll see a list of problematic types of footage and some suggestions for how to deal with some of the problems. There are other problems that will just be problematic no matter what.
    Pete
  • Yong jin Lam
    February 17, 2011 at 11:26 pm
    alright boss, thanks a lot… only haf access to my footages nxt wk. will try it out n let u knw. ty for replying.
