Activity › Forums › Adobe After Effects › I have a problem with converting mjpeg avi and audio
  • I have a problem with converting mjpeg avi and audio
    Posted by Chang hun Kim on February 28, 2011 at 4:19 pm
    My client want me to convert video as a specific format which I don’t know how to do it.
    Video Format is
    File Extension : *.avi
    Format : AVI
    Video Codec : mjpeg
    Resolution : 480×234
    Aspect Ratio : 80:39
    Video Bitrate : 2000kbit/s – 2500kbit/s
    Frame/Sec : 20-25 fps
    Audio Codec : pcm_s16le
    Audio Bitrate : 128kbit/s
    Sampling Frequency : 44.1 or 48kHz
    I did research on internet and found that I can use VirtualDub with Morgan M-JPEG codec V3 to convert video but I didn’t find a way to convert audio as pcm_s16le. I don’t even have any idea about what pcm_s16le is.
    I see only pcm menu in the VirtualDub audio compression setup menu.
    Are they, I mean pcm and pcm_16le, really different?
    please help me.
    Chang hun Kim replied 15 years, 7 months ago 2 Members · 2 Replies
  • Cory Petkovsek
    March 1, 2011 at 9:13 pm
    It means signed 16-bit little endian. Unless you’re working on big iron unix (not with AE), your processor is little endian. The difference between signed and unsigned is significant for numbers >=2^15 or negative. Look it up if interested. But basically it will probably work just fine as pcm_16le which doesn’t specify if it is signed or unsigned.
    Cory
    Corporate Video
  • Chang hun Kim
    March 1, 2011 at 10:02 pm
    Thank you Cory,
    You’re my Savior!
    I’ve just sent encoded mjpeg avi with pcm audio file to my client.
    I’m just waiting if my client would complain about it or not.
    Thanks for the knowledge about difference between two!!
