Activity › Forums › Adobe Premiere Pro › I have a pretty high spec PC but editing 4k in premiere is struggling.
  • I have a pretty high spec PC but editing 4k in premiere is struggling.
    Posted by David Hare on February 18, 2016 at 2:11 pm
    Hi all im hoping someone can give me some advice. I have a pretty high spec PC but when im editing 4K from the Black Magic either in MOV or RAW it seems to struggle. my specs are
    Windows 7 professional
    64Gb Ram
    Titan X
    Intel i7-3930K CPU @3.20GHz
    2 western digital 6Tb black in a raid.
    SSD for windows and adobe.
    hybrid for adobe Chache
    Im just wondering if its the way its set up or if im missing something.
    Cheers
    Tim Kolb replied 10 years, 7 months ago 4 Members · 3 Replies
  • Jeff Pulera
    February 18, 2016 at 3:02 pm
    Hi David,
    Is Mercury GPU Hardware Rendering enabled? Have you tried setting the Program Monitor resolution to 1/2?
    Your PC specs certainly look more than adequate! Which version of Premiere?
    In general, when using any card-based format in Premiere, make sure to copy the entire contents of the card to a folder on your hard drive, keeping entire folder structure intact. There is “metadata” which is crucial to Premiere located inside. Then import into Premiere using “Media Browser” rather than “File > Import”. I’ve seen this improve playback for AVCHD and such, maybe it will help you if not already doing this.
    Jeff Pulera
    Safe Harbor Computers
  • Alex Udell
    February 18, 2016 at 3:03 pm
    Hi….
    the overall cpu spec is quite good.
    RAW 4k sounds like you drives won’t keep up with that.
    When you say .mov, what codec?
    How is the RAID attached to your system?
    My guess is that the data rate is too high for a 2 drive array.
    You might flip the footage to GoProCienform, ProRes, or DNXHD, to reduce the demand on your drives and it’s connection to your CPU.
    hth,
    Alex Udell
    Editing, Motion Graphics, and Visual FX
    Let’s Connect on Linkedin
    Examples: Retail Automotive Motion Graphics Spots
    Example: Customer Facing Explainer Video
    Example: Infotainment & Package editorial
  • Tim Kolb
    February 22, 2016 at 11:45 pm
    I think Alex is thinking the same way I am…those two 6 TB drives may be the bottleneck.
    RAW will certainly tax a processor, but depending on what the format of the .mov files are, they may be quite large…
    TimK,
    Director, Consultant
    Video Producer at I-CAR
