Activity Forums Apple Final Cut Pro Legacy I have a file that is Spanned file on a p2 card on one disc the other is ereased?
  • I have a file that is Spanned file on a p2 card on one disc the other is ereased?
    Posted by Stephen Hoyal on April 20, 2009 at 10:02 pm
    HI everyone,
    I have a question for everyone. I have a spanned file on a p2 card. I eraesed the other p2 card before I know that I had spanned footage. I have been transferring to final cut pro on my lab top. The file will not transfer over but it is their and I can watch it.
    My question, since the other footage is erased on the other p2 card all I need is the footage on this file on this p2 card. How do I get the footage on the P2 card.
    Steve
    Les Kaye replied 17 years, 4 months ago 3 Members · 2 Replies
  • Cheyenne Pesko
    April 21, 2009 at 1:15 am
    Hi there.
    When you add the spanned clip to the queue in the Log and Transfer Window does it give you some kind of error? Spanned or not, FCP should still be able to process the clip(s) on the card.
    Cheyenne
    As above, so below.
  • Les Kaye
    April 22, 2009 at 6:06 am
    This doesn’t answer the problem, but an FYI. I just had to do a recapture of P2 material backed up on a hard drive. Although the method recommended by those here MOSTLY worked, there were issues with spanned files. Sometimes Log and Transfer would import immediately, sometimes I’d have to do the spanned files in a separate session. Sometimes a new partial file would be created. And out of hundreds of files, there were about 8 or 9 that never automatically imported. I had to manually do it.
    http://www.leskaye.net
