Activity Forums Adobe Premiere Pro I have a damaged project on ppro cs4 that doesn’t want
  • I have a damaged project on ppro cs4 that doesn’t want
    Posted by Gil Sabag on April 4, 2011 at 7:55 am
    to load up all the mxf footage,in the middle of loading the footage it refuses to load a specific footage and the project freezes and when I relocating the footage it get stuck on and make offline it get stuck on a different footage,and since the footage r mxf files I have to load like 2500 of them and every time it get stuck on a different one.I think the importer prodess server gives me the problem with the loading,when I’m opening a new project or using one of the old versions of the autosave the footage is loading properly,only when I open the finish project it get stuck,Is there a way to recreat the finish project?I’v tried to import the project in a new project and it get stuck,also I’v also tried to load the sequences and it get stuck,I renamed all the folders to open it ass offline project and link the media but it get stuck,and I’v saved it under a different name befor it freezes also the newe save have the same problem,anyone has any idea how to load up this project,I’v spent so many hours on it,and I have like an hour work of fixing and this happend,please if anyone can think of somthing?Thanks
    Toby Gale replied 15 years, 5 months ago 3 Members · 2 Replies
  • Tim Kolb
    April 4, 2011 at 1:36 pm
    It sounds like you’ve covered most of the bases.
    As a last resort, I’d try cleaning the Media Cache from the preferences, and if that doesn’t do it, I’d say you might be left with reworking the changes since the last auto-save.
    My auto-save is set pretty aggressively, so I only lose 10 minutes or less of the last work I did.
    TimK,
    Director, Consultant
    Kolb Productions,
  • Toby Gale
    April 4, 2011 at 10:23 pm
    make a safe copy of the PP broken finalised file right click and open with a text editor. do this with a working auto save file and scan for any odd brakes in meta tags this isa long shot but might reveal a problem Perhaps caused by damaged harddisk or failed write process.
    best of luck.
    do you have time machine on a mac?
    Computer animation Student
    MACHINES
    > Mac Book Pro 13” 4 gig Ram Nvdia320m intel dual core.
    > PC – 16GB Ram Quad core intel 1TB 2×24” HP monitors
    SLI 2X nvidia Geforce GT9800 windows7 ultimate +ubuntu
    CAMERA
    > Panasonic HDC SD700 2×8 GB
