I-Frames and GOP
Posted by Dale Spetz on March 3, 2011 at 2:32 pmWhen rendering out MPEG-2, is I-Frame=1 and B-Frame=0 the same as “no GOP?”
Dale Spetz replied 15 years, 6 months ago 2 Members · 4 Replies -
John Rofrano
March 3, 2011 at 4:06 pm -
Dale Spetz
March 3, 2011 at 4:18 pmThank you, John, for confirming this!
I believe that I’ve got this MPEG-2 PAL conversion down, per your MainConcept recommendation. But, if I apply any value to “VBV Buffer Size”, the output goes blotchy. With noGOP, is a VBV value necessary for TV broadcast? Can I leave it at zero?
John Rofrano
March 3, 2011 at 4:43 pm[Dale Spetz] “But, if I apply any value to “VBV Buffer Size”, the output goes blotchy. With noGOP, is a VBV value necessary for TV broadcast? Can I leave it at zero?”
I have no idea what that advanced parameter means. I would just leave it at the default.
~jr
http://www.johnrofrano.com
http://www.vasst.com
