Activity › Forums › Apple Final Cut Pro Legacy › I edited in the wrong pixel aspect ratio!
  • I edited in the wrong pixel aspect ratio!
    Posted by Mbiehn on June 13, 2007 at 2:11 am
    Hello all,
    I’ve just come to realize that I’ve edited quite a few scenes in a movie in the wrong pixel aspect ratio. When I attempt to change the aspect ratio or copy and paste the scene into a new corrected sequence the aspect ratio assignment seems to stay with it and distorts the picture. So as of right now I cannot edit them together, because either refuses to conform to the correct pixel aspect ratio. Can anyone tell me how to conform clips’ pixel aspect ratio after they’ve been edited? Please help me. I’m going to have a heart attack. Thanks.
    Rafael Amador replied 19 years, 3 months ago 3 Members · 2 Replies
  • Christian Kinnard
    June 13, 2007 at 4:08 am
    Once you place them in the sequence with the correct aspect ratio settings, right click on all the selected clips and click remove attributes. Check the distort box and hit ok. Everything should pop to it’s correct aspect ratio.
    Christian
  • Rafael Amador
    June 13, 2007 at 3:36 pm
    I don’t know if you set wrong the pixel aspect ratio of your sequence or of your clips.
    The pixel aspect ratio of your sequence you change it in the setting. The pixel aspect ratio of your footage you have to cahnge it in the Brownser windo. But when you change it, the clips that you have lied before keep the brong aspect ratio so you must reset the distortion.
    Rafael
