Activity › Forums › Adobe After Effects › I don’t want to loose quality when exporting – Help!
  • I don’t want to loose quality when exporting – Help!
    Posted by Deborah.blu on October 20, 2007 at 10:10 am
    Hi guys!
    I usually import a clip .mov (High Definition), than I work on it with AE (e.g. I add a map on the upper left corner), but when I export it as a quick time movie, the quality is not the same of the original.
    I think that probably I don’t use to correct settings.
    Which are the good ones in order to have a final clip of the same quality of the original?
    May anyone help me?
    Debbie
    Deborah.blu replied 18 years, 11 months ago 3 Members · 6 Replies
  • Richard Harrington
    October 20, 2007 at 2:36 pm
    What are you exporting from to AE
    Richard M. Harrington, PMP
    Author: Photoshop for Video, Understanding Adobe Photoshop, and ATS:iWork
  • Deborah.blu
    October 20, 2007 at 3:58 pm
    Hi Richard!
    I hope to understand your question, english is an issue for me!
    I import in AE a 1920×1080 .mov file and then I export a 1920×1080 quicktime movie. But in the exported file I see lots of artifacts.
    Thanks for your time. Debbie!
    October 20, 2007 at 4:53 pm
    Look at your Output Module from AE and check what quality and codec settings you are using
  • Darby Edelen
    October 20, 2007 at 9:41 pm
    [deborah.blu] “I import in AE a 1920×1080 .mov file and then I export a 1920×1080 quicktime movie. But in the exported file I see lots of artifacts.”
    What kind of compression are you using on the file before AE? And what settings are you using when you render from AE? If you render Lossless from AE then you should see no degradation in the footage, but your file sizes will be very large.
    Which reminds me, don’t use the Export command from AE, use Make Movie or Add to Render Queue.
    I apologize if the language barrier causes any problems here =/
    Darby Edelen
    DVD Menu Artist
    Left Coast Digital
    Aptos, CA
  • Deborah.blu
    October 22, 2007 at 8:24 pm
    I connect my HD videocamera to the iMAC and I import the tape via Final Cut.
    Final Cut put all clips in a folder. (There’s no compression here: clips are same quality then the original tape – HDV1080i)
    Then I import in AE the file that I want to work from that folder.
    I make movie with best settings and looseless (quicktime movie and compression settings HDV 1080i).
    As said before, I see artefacts on the rendered movie.
    Thanks again for your interest in my problem.
    Debbie.
  • Deborah.blu
    October 23, 2007 at 3:15 pm
    OK!
    Thanks for your precious information.
    Debbie
