Activity Forums Apple Final Cut Pro Legacy i click on the FCP icon, nothing happens
  • i click on the FCP icon, nothing happens
    Posted by Sam Pope on January 4, 2009 at 9:50 pm
    So, before I had a problem with some subclips going offline and trying to to reconnect them. In the process of trying to fix that, i re-arranged some stuff in the scratch drive, deleted some preferences and then emptied the trash. As soon as I emptied the trash, FCP refused to open. I click on the icon, and NOTHING happens. It bounces once and that’s it. I try to open a project file and the same thing. NOTHING happens. My instinct would be to just reinstall FCP, but I really don’t have time to do that, especially since I would also need to update it…
    Any ideas of how I did this and what I can do to fix it?
    Thanks.
    Edo Medicks replied 17 years, 8 months ago 5 Members · 5 Replies
  • David Roth weiss
    January 4, 2009 at 10:03 pm
    [Sam Pope] “My instinct would be to just reinstall FCP”
    That should be the absolute last instinct you should ever have Sam. Clearly your tinkering with files seems to have created this problem.
    Here’s what I would do…
    1. Trash your prefs again
    2. Open a new project in FCP and test to see that everything works.
    3. If it does, you’d better start figuring out what the heck you did to your old project when moving those files.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Sam Pope
    January 4, 2009 at 10:49 pm
    Yeah, that was the first thing that I did – trash my preferences again. But still nothing. I click on the FCP icon, in the dock and nothing happens. It doesn’t even try to open. Same if I click on any project files.
    I really have no idea what to do…
    Thank You.
  • Rafael Amador
    January 5, 2009 at 3:28 am
    Try to install the last FC update that you had already install.
    If the system don’t let you install it, delete the receipt corresponding to that installation.
    Rafael
    http://www.nagavideo.com
  • Phillip Van west
    January 5, 2009 at 5:57 am
    Have you tried double-clicking on the application icon itself, in the apps folder? Sometimes a dock icon becomes disassociated with the application it represents. Worth a try…
    pvw
    Phil Van West
    Terra Nova Productions
    Denver, CO
    Video Production/Post-Production
    G5 DP 2.5GHz / 4.5 GB RAM / OS 10.5.6 / FCP 6.0.5 / QT 7.5
  • Edo Medicks
    January 5, 2009 at 12:36 pm
    I just made a post on fixing some issues with FCP on 10.5.6. https://www.uncarvedblog.com/files/17e6d3fd887301579e655aa7cb9d7b3e-37.php
    Maybe it can help you too.
    look towards the bottom of the post, you can find links to these tools;
    PrefTrasher
    FCS Remover
    basically, you need to trash Prefs (use PrefTrasher), and the cache folders (thumbnail, waveform), mostly it works.
    if not, and you have to re-install, use FCS remover (many folders are strewn across the System, very hard to do manually).
    it solved my issues.
    before re-installing, try in a diffrent user account, safe boot, permissions etc. (surly you already did that…)
    hope it works
    The cup is half full and my shirt is half wet
