Activity › Forums › Apple Final Cut Pro Legacy › i cant seem to find the right codec
Posted by Mark Francis on June 17, 2011 at 8:52 ami used an apple animation codec in stomp and that reduced my file size to 110 mb from 600 mb i then imported my 110 mb file into fcp5 and exported as a QT movie when i played it back my cg rendered image was very soft. what else can i do to solve this problem?
Rafael Amador replied 15 years, 3 months ago 3 Members · 14 Replies -
Michael Gissing
June 17, 2011 at 10:09 am600mb is a small file. Why would you reduce it? Animation codec shouldn’t reduce the size at all. Are you sure you don’t mean Apple Intermediate Codec? If so that is a lossy old codec. What codec is the original file?
Rafael Amador
June 17, 2011 at 12:43 pmMark,
Your picture looks like a B&W matte. Why are you using animation?
Animation makes sense only if you need keep on those 8b RGB.
For a B&W matte, “Animation 256 Grays” would gives you the same result than “Animation Millions”, but files 3 folds smaller.
For any other purpose, there are better options: For a B&W matte, you can use almost whatever codec. The better the codec, the better the matte. You only need the luma channel).
If you need an Alpha channel, Prores 444 gives you a better one.[Michael Gissing] “600mb is a small file. Why would you reduce it? Animation codec shouldn’t reduce the size at “
I guess his original stuff is NONE or another heavy raw 8b RGB.
Animation reduce highly the file size keeping the full RGB info (lossless).
rafael -
Mark Francis
June 18, 2011 at 7:26 ami cant find the Prores 444 codec and its not a matte as such its an ambient occlussion render from a 3d programme. its a cgi image. i really need to unsoften these movies, any more advice would be great
Rafael Amador
June 18, 2011 at 9:07 am[mark francis] “its a cgi image.”
I understand that you haven’t make that by hand.[mark francis] “its not a matte as such its an ambient occlussion render from a 3d programme.”
OK, call it as you want. Is a Gray Scale (B&W) matte, wherever comes from.
RGB values are the for each pixel: R = G = BIf no Alpha going on, do it with any 10b codec.
rafael -
Rafael Amador
June 19, 2011 at 4:50 pm[mark francis] “whats a 10b codec?”
That I’ll tell you later.The question is why your picture are getting soft.
If you are starting with a Still sequence of PNG, TGA, TIFF,… and you export that as a a QT Animation, its shouldn’t be no degradation at all. During your rendering/exporting must be something more than just a re-encoding.
Which kind of graphics are you using?
Which size?
Which are your sequence setting?
Are you resizing?
Is EVERYTHING PROGRESSIVE (NONE)?
ARE YOU RENDERING IN 8b RGB?
rafael -
Mark Francis
June 20, 2011 at 8:34 am -
Rafael Amador
June 20, 2011 at 11:18 amMark,
You started by saying that you are working on Animation, but what I see you is a very compressed H264.[mark francis] “whats a 10b codec?”
[mark francis] “but i dont understand the questions, Are you resizing? and Is EVERYTHING PROGRESSIVE (NONE)? ARE YOU RENDERING IN 8b RGB?”
A doctor should know about the liver, heart, lungs, etc, before starting the operation.
If you don’t understand my questions, you don’t have the elements to set a proper workflow.
You need to understand the raw material and the processes to avoid degradation in postproduction.I propose you an easier way for you to make a movie with your stills sequence.
– Open QT Player
– Menu File> Open Still sequence.
– Select your stills folder.
– Set the Frames per second.
When you have the movie opened in the Finder, “Export” with “current setting” to the codec you want.
rafael -
Mark Francis
June 21, 2011 at 8:58 amok this is what i did, in QT player i went to,
1 file>open image sequence, i then loaded in my tiffs
2 file>export in this pop up box i choose, export: movie to QT movie and saved it to my desktop. i then opened it in fcp5 and the image was again too soft. im lost
Mark Francis
June 22, 2011 at 7:57 amok this is what i did, in QT player i went to,
