Activity › Forums › Apple Final Cut Pro Legacy › i cant seem to find the right codec
  • Rafael Amador
    June 22, 2011 at 8:54 am
    [mark francis] “2 file>export in this pop up box i choose, export: movie to QT movie and saved it to my desktop. i then opened it in fcp5 and the image was again too soft. im lost”
    And you exported to what?
    The same crappi H264?
    rafael
    http://www.nagavideo.com
  • Mark Francis
    June 23, 2011 at 8:03 am
    no i experimented and used a lot of these presets in a compressor called stomp. i saved out my tiff sequence, compressed them in here and when i opened the compressed version up in fcp they were still to soft.
  • Mark Francis
    June 24, 2011 at 8:38 am
    no i experimented and used a lot of these presets in a compressor called stomp. i saved out my tiff sequence using QT, compressed them here in stomp and when i opened the compressed version up in fcp they were still to soft. i1.creativecow.net/u/143950/0_picture5.png’>
  • Rafael Amador
    June 24, 2011 at 12:03 pm
    [mark francis] “no i experimented and used a lot of these presets in a compressor called stomp. i saved out my tiff sequence using QT, compressed them here in stomp and when i opened the compressed version up in fcp they were still to soft.”
    OK, so forget about that “stomp”.
    Do what I told you: Open the sequence with QT and export to Animation, Prores or whatever other quality codec. Just need to set the “frames per second’ you want your movie. Keep the same size.
    As I told you, you could export that as “256 Grays” (Your picture is B&W. You don’t need the 3 RGB channels) that makes files 3 folds smaller than “Animation Millions”
    rafael
Page 2 of 2
