Activity › Forums › VEGAS Pro › I can’t render in HD anything!
  • I can’t render in HD anything!
    Posted by Chris Duke on March 26, 2011 at 12:38 am
    I have been fighting with Vegas for the last 6 months and still can’t render in HD.
    I just dropped $300 into my computer. I bought a graphics card with a gig of ram on it and a 600watt power source, which means I have a grand total of 9GB of ram, 1TB of memory, quadcore processor, and 64bit.
    Basically there is no reason I shouldn’t be able to render in HD. There is no way that every single clip I have is corrupted either. I get the classic “Error low memory” message. Is it possible to designate every single spec of memory to vegas to try and render a file?
    PLease please please, someone for the love of God help me!
    John Rofrano replied 15 years, 5 months ago 4 Members · 13 Replies
  • 13 Replies
  • John Rofrano
    March 26, 2011 at 12:47 am
    [Chris Duke] “There is no way that every single clip I have is corrupted either. “
    No, but it could be the type of video that you are editing that’s causing the problem. What is the format of your source media? Where did it come from? What codec does it use?
    Also what is your Dynamic RAM preview set to? (look in Options | Preferences | Video for Dynamic RAM Preview).
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Stephen Mann
    March 26, 2011 at 2:50 am
    Makes no difference to Vegas.
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Nigel O’neill
    March 26, 2011 at 9:33 am
    Chris
    I get this error regularly and ‘get around it’ by using the 64 bit version of Vegas. If you are using a 64 bit operating system, install the 64 bit version of Vegas and it should render.
    The 32 bit version of Vegas can co-exist with the 64 bit version. Be aware that some 3rd party plug-ins may not work under x64 Vegas, so you need to check your time line.
    Intel i7 920, 12GB RAM, ASUS P6T, Vegas Pro 10 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • Chris Duke
    March 26, 2011 at 7:54 pm
    I am still pretty new to all of the terms for media. But they are .mov’s from my canon T2i. My preview is set as low as it can be.
    I have tried every “fix it” method that I could find online as well.
  • Chris Duke
    March 26, 2011 at 8:00 pm
    Does HD Platinum 10 have that option? I was told to look for updates, but I feel like all I did was re download the program, and that it didn’t actually update anything.
  • John Rofrano
    March 26, 2011 at 9:48 pm
    [Chris Duke] “Does HD Platinum 10 have that option?”
    If by “that option” you are referring to a 64-bit version the answer is no. Vegas Movie Studio HD is 32-bit only.
    [Chris Duke] “I was told to look for updates, but I feel like all I did was re download the program, and that it didn’t actually update anything.”
    There are no updates for Movie Studio HD 10 yet but when there are, you do download the whole program again and it re-installs itself.
    ~jr
  • John Rofrano
    March 26, 2011 at 9:56 pm
    [Chris Duke] “I am still pretty new to all of the terms for media. But they are .mov’s from my canon T2i. My preview is set as low as it can be.”
    Well… there’s your problem right there. The Canon T2i files are a non-standard format that is extremely difficult to edit. From your other post I gather you are using Movie Studio HD and that doesn’t handle movie files from still image cameras very well.
    You’re going to have to convert those files to something that Movie Studio can edit. I would recommend looking at CineForm NeoScene ($99 USD) which can convert the Canon files into a more editable format. Download the trial and see for yourself.
    ~jr
  • Chris Duke
    April 4, 2011 at 10:40 pm
    Re-saved the video files, and it still won’t render.
  • John Rofrano
    April 6, 2011 at 12:52 pm
    [Chris Duke] “Re-saved the video files, and it still won’t render.”
    Can you please explain what, “re-saved the video files” means? What exactly did you do to “re-save” them? Did you try CineForm as I suggested?
    ~jr
  • Chris Duke
    April 7, 2011 at 4:28 pm
    I re-saved them as .wmv files using vegas. 1080 30fps and 720 60fps.
    I didn’t try the site you suggested, but only because I wanted to try a solution that wouldn’t cost me a hundred dollars, only to have it still not work.
