Activity › Forums › VEGAS Pro › I can’t render in HD anything!
  • John Rofrano
    April 7, 2011 at 5:45 pm
    [Chris Duke] “I re-saved them as .wmv files using vegas. 1080 30fps and 720 60fps.”
    Unfortunately, that was not the best choice of formats. WMV uses a highly compressed interframe codec just like the Canon files you’re trying to get away from. The reason I recommended CineForm is because it uses a interframe codec that is designed for smooth editing and comes with a tool that is specifically designed to convert Canon 5D/7D/T2i files. It’s the right tool for the job.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Chris Duke
    April 8, 2011 at 1:53 am
    Downloaded the trial version, no idea how to use it. All it did was down load forms for me to read and no actual program.
  • John Rofrano
    April 8, 2011 at 2:27 am
    [Chris Duke] “Downloaded the trial version, no idea how to use it. All it did was down load forms for me to read and no actual program.”
    There should have been a program that you install and run. When you run it, you can open your video files and have it convert them to the CineForm codec for you.
    ~jr
Page 2 of 2
