Activity › Forums › Adobe Premiere Pro › I can’t make a H.264 with multiplex audio in AME CS4
  • I can’t make a H.264 with multiplex audio in AME CS4
    Posted by Joe Bandy on May 23, 2010 at 7:24 pm
    I was trying to make a H.264 with embedded audio in AME CS4. In the encoder window under the multiplexing tab I have TS selected. I can open the encoder and see the Job in the Queue but whenever I start the encode it never encodes the file. After about 6min. I receive a yellow triangle with exclamation point in the center that appears to the right of the job in the queue and the encoding fails, I’m not sure what I’m doing wrong.
    I’m making a h.264 for Blu-ray 720p 59.94fps file 16:9 audio 16 bit 48khz.
    Ann Bens replied 16 years, 4 months ago 2 Members · 1 Reply
  • Ann Bens
    May 24, 2010 at 4:18 pm
    Doubble click on the yellow triangle and you will seen why.
