Activity Forums Adobe Premiere Pro I can’t import Q-T to the Premier CS3
  • I can’t import Q-T to the Premier CS3
    Posted by Aris Gharibain on April 24, 2009 at 2:50 am
    I shot with sony EX3 and convert the footage to Q-T (1920×1080) I don’t have Mpeg 4 footage anymore. But I can’t import it to the Premier CS3. I have a Quad-core PC windows vista 64 bit with 2.66GHz. I’ll appreciate your help in this matter.
    Ari
    Seth Fair replied 16 years, 6 months ago 4 Members · 4 Replies
  • Nick Hill
    April 24, 2009 at 4:58 pm
    Hi Ari
    What QT codec did you use? Quicktime is a kind of wrapper format – ie, it can use many different types of codec, some of which Premiere might not handle properly (I know for example Premiere on Windows can’t use certain FCP quicktimes without conversion). You may have to convert the quicktimes again. Incidentally if you have the latest version of CS3 (3.2? I think) this should handle the native MP4s straight out of the camera without having to convert.
    Hope that helps
    Nick
  • Aris Gharibain
    April 24, 2009 at 5:11 pm
    Hi Nick,
    The codec is: XDCAM EX 1080i60 (35Mb/s VBR) integer (big endian), timecode. Unfortunately, I don’t have the MPEG 4 files anymore.
    Best,
    Ari
  • Antonio Oliveira
    November 3, 2009 at 2:49 pm
    Hello 🙂
    I want to import an mpeg-4 video file for the Premiere CS3 …
    How can I do that?
    Is an urgent matter!
    Be fine
    Hello 🙂
  • Seth Fair
    February 18, 2010 at 4:54 am
    I found that importing into After Effects works fine, even though importing into PremirePro causes an error. After you have imported the files into After Effects, you can export it as a Premiere Pro project under File-> Export. You goto Premiere Pro and for some reason everything opens fine without any errors and no file conversions.
