Activity Forums Media 100 i can’t import FinalCut files in M100, problems with upper/lower field
  • i can’t import FinalCut files in M100, problems with upper/lower field
    Posted by Macmauro on November 28, 2005 at 1:16 am
    I tryed to import in M100 8.2.2 os 10.3.9
    files PAL at DV quality 720×576 created in and exported from Final Cut Pro 4 as quick time
    when m100 is asked to import these files a message appears saying
    i have to use upper field option in quick time when i create the file
    anyway it imports the file but the result is a bad motion and strange colors clip
    but also using the upper field option in Final Cut the message still appears
    and the result is the same
    the media100 runs under Quicktime 6.4
    Final cut under quick time 7.
    Could this be the problem?
    How to avoid it?
    in case could i upgrade to QT 7 the media100 computer?
    thanks
    Macmauro replied 20 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
