Activity Forums Adobe After Effects I can’t hear the sound.
  • I can’t hear the sound.
    Posted by Miriam Millan on September 23, 2005 at 4:14 pm
    I have a problem with audio. Can you edit audio in the After Effects timeline? I can preview audio by using the period key in the numbers key pad, but once i render and make a movie there is no audio. Please help.
    Miriam
    Miriam Millan replied 21 years ago 2 Members · 2 Replies
  • Michael Hancock
    September 23, 2005 at 5:19 pm
    When you render, go to your Make Movie render queue and click on the output module. At the bottom of your options is Audio. Be sure the Audio box is checked. It’s easy to forget to do this. I’ve rendered countless animations only the discover after the fact that I forgot to enable the audio. Pretty discouraging after a multi-hour render.
    Hope this works.
    Michael.
  • Miriam Millan
    September 25, 2005 at 6:40 pm
    Hi Michael,
    Thanks for your help. It works, now I have to figure out how to cut it to the music. It’s possible, right?
    Miriam
