Activity › Forums › Adobe Premiere Pro › I can’t get a project from a previous version of Premiere to convert within 5.0.0
  • I can’t get a project from a previous version of Premiere to convert within 5.0.0
    Posted by Matthew Cremer on October 31, 2012 at 10:14 pm
    For starters, when I tried to open the project, it said the scratch disks are write protected or unavailable. To open the project I would need to set the scratch disks to somewhere on my hard drive. I went ahead and continued and have tried to convert the project into my version of Premiere. It is taking quite a bit of time to do so. I am not sure if this will even work.
    Thanks for any insight.
    Angelo Lorenzo replied 13 years, 11 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    November 1, 2012 at 1:20 am
    Premiere will up-convert any project files from previous versions. It’s usually never a problem to go from cs4 -> cs5 and so on, but nearly impossible to go backwards from, say cs6 -> cs5.
    Let us know if you get any actual error messages.
    Angelo Lorenzo
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
