Activity Forums Adobe After Effects I can’t find “position XY” in trapcode
  • Cassius Marques
    January 23, 2018 at 7:19 pm
    Your “Emitter” is set to Lights, its position should be any light’s position. Change from Lights to Point to enable the position property to be set.
    Cassius Marques
    http://www.zapfilmes.com
  • Cassius Marques
    January 23, 2018 at 7:21 pm
    Your “Emitter” is set to Lights, its position should be any light’s position. Change to point to enable the position. Though you won’t have position XY. Newer versions of particular use a 3 array property. [X,Y,Z]. But you should be ok following the tutorial.
    Cassius Marques
  • Donny Purbagas
    February 21, 2019 at 7:58 am
    change your version plugin to trapcode particular 13.0……
