Activity › Forums › Adobe Premiere Pro › I can’t capture HDV
  • I can’t capture HDV
    Posted by Rabin Rai on May 21, 2009 at 1:35 am
    Dear folks;
    I can capture DV successfully with no problem but I can’t capture HDV.
    I tried different HDV pre-sets for project settings, I can playback the HDV on the capture window. But when I press capture button on device control, it just says capturing and captures NO audio and video.
    I have Dell Inspiron 6400 laptop and Sony HDR Fx-7 cam as hardware. I use firewire to transfer video.
    Adobe Premiere Pro 2 as software.
    I will appreciate your help.
    Thanks in Advance!
    Rabin Rai replied 17 years, 4 months ago 3 Members · 6 Replies
  • James Orlowski
    May 21, 2009 at 12:36 pm
    Perhaps the issue is with version 2.0? I remember reading somewhere that starting with 3.0, Premiere was better able to handle HDV.
    I use 3.0 and have no issues capturing HDV from my Canon XH-A1.
    James Orlowski
    RYNO Production, Inc.
    http://www.rynoproduction.com
    800-860-7966
  • Eddie Lotter
    May 21, 2009 at 1:11 pm
    Be sure to switch your camcorder from DV to HDV while it is unplugged from your computer.
    Cheers
    Eddie
  • Rabin Rai
    May 21, 2009 at 1:57 pm
    Eddie,
    I have no problem with the camcorder setting. I have done that after reading one of the forums. But the link seems to be quite helpful.
    I appreciate your help.
    Cheers!
  • Rabin Rai
    May 21, 2009 at 1:58 pm
    Thanks for info.
    I will give it a try and let you know the result.
  • Eddie Lotter
    May 21, 2009 at 9:37 pm
    [Rabin Rai] “I appreciate your help.”
    You’re welcome. 🙂
    Cheers
    Eddie
  • Rabin Rai
    May 21, 2009 at 11:52 pm
    I installed Adobe premiere pro CS3 and it got even worse. It doesn’t show me the HD presets. Could it be because my Graphics card doesn’t support HD?
    I ran “dxdiag” and found following details for my display card..
    Name: Mobile Intel(R) 945 GM Express Chipset Family
    Chip type: Calistoga Graphics Controller.
    Approx memory:224 MB
    Current display mode: 1280X800 32 bit, 60 Hz.
