Activity Forums Apple Final Cut Pro Legacy I can’t burn my project onto a disc. Why?
  • I can’t burn my project onto a disc. Why?
    Posted by And Grill on April 16, 2013 at 1:46 am
    I used the DVD feature on final cut pro to burn my disc, I didn’t use a compressor or anything. The disk burns, but when I try to play the video from the disc, a folder pops up that just has the files AUDIO.TS and VIDEO.ts, nothing to actually play. I need help on this soon. Thanks
    John Pale replied 13 years, 4 months ago 4 Members · 6 Replies
  • Shane Ross
    April 16, 2013 at 3:53 am
    You need to put it into a DVD player, or use the DVD Player app on your computer
    Shane
    Little Frog Post
  • And Grill
    April 16, 2013 at 4:19 am
    Where is the DVD player app? I can’t find it through search or in the applications folder
  • Rafael Amador
    April 16, 2013 at 12:39 pm
    [and grill] “Where is the DVD player app? I can’t find it through search or in the applications folder”
    You should have it.
    Is one of the basic application that comes bundle with MacOSx.
    If is not over there, you have to reinstal the system.
    If you don’t want, you can install VLC:
    https://www.videolan.org/vlc/download-macosx.html
    Will be able to read the disk (Open Disc).
    rafael
  • And Grill
    April 16, 2013 at 11:45 pm
    I guess it’s called “Front Row” now, as I was able to play the DVD through that perfectly fine. Thanks
  • Rafael Amador
    April 17, 2013 at 4:19 am
    [and grill] “I guess it’s called “Front Row” now, “
    Wow!!
    I’m obsolete (Snow Leopard).
    rafael
  • John Pale
    May 14, 2013 at 8:45 pm
    It’s not called Front Row.
    that was an app that Apple released for awhile. It was basically the same interface as AppleTV for use on a computer being used as a media center (a MacMini in most cases). They eventually discontinued it. The DVD Player app sounds like its missing from your system for some reason.
    If you want it back, you are going to have to reinstall the OS or use a third party app, like Pacifist, which can extract it from the MacOSX installer.
