Activity Forums Adobe Premiere Pro I cannot get my clips to play
  • I cannot get my clips to play
    Posted by Scott Elkins on October 21, 2011 at 3:05 am
    Help, I have run out of ideas. I’m a new convert to Adobe Premier Pro cs5.5 from
    Final Cut Pro 7. I have a MacPro, 32GB ram, Snow Leopard, everything up to date.
    Yesterday I worked on a tutorial from Linda.com, downloaded the work files, everything
    worked great, life is good. Today I started Premier Pro, dropped a clip into the timeline,
    hit the space bar to play…nothing happened! OK tried another clip, still nothing.
    I Imported some P2 footage that I had been working on in FCP, still nothing. Even tried
    some still jpeg pictures, nothing. I can scrub without any problem. I can use the jog wheel
    without any problem. I can use the shuttle without any problem. I can use the arrows
    forward and reverse without any problem. Anytime I try to play a clip, either in
    the timeline or the source window, it will not work. I have tried using the space bar,
    the “play triangle”, the “J” “K” “L” keys but no luck. I reinstalled Premier Pro and that
    did not help. I am sure I have done something stupid, but I have run out of ideas.
    Remember everything worked fine yesterday, does anyone have a suggestion?
    Scott Elkins replied 14 years, 11 months ago 3 Members · 4 Replies
  • Jeff Pulera
    October 21, 2011 at 1:50 pm
    Hi Scott,
    This happened to me once where the spacebar wouldn’t work, and it was because I had the “loop” button highlighted under the Program window, check that first.
    Jeff Pulera
    Safe Harbor Computers
  • Scott Elkins
    October 21, 2011 at 2:12 pm
    Thanks for that info. I just checked that and the loop button is not highlighted. But that’s something I didn’t know until now.
  • Kevin Monahan
    October 24, 2011 at 3:56 pm
    Try the steps in this document: https://kb2.adobe.com/cps/842/cpsid_84287.html
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Scott Elkins
    October 24, 2011 at 5:50 pm
    Thanks to everyone. I found that my video card was not up to the task.
    I was using 3 monitors and I eliminated 1 monitor and everything
    works great. I still don’t know how or why it worked before. I guess
    I will have to get a CUDA card if I want 3 monitors. After using
    Premier Pro I don’t think I need 3 monitors. My current arrangement
    I use my 27″ for the program and use my 22″ monitor for viewing.
