Activity Forums Maxon Cinema 4D I can´t work in the interior of a object, its becomes invisible. Cinema 4D
  • I can´t work in the interior of a object, its becomes invisible. Cinema 4D
    Posted by Eliseo Salomon on September 4, 2016 at 9:07 pm
    I have been serching a way to see inside of a head object with which I am working. When I want to see the inside it is gets invisible . It should be easy but I am new whith the “Cinema 4D”
    It should not be the appropriate work mode.
    Someone know what I am doing wrong?
    Adam Trachtenberg replied 10 years ago 2 Members · 1 Reply
  • Adam Trachtenberg
    September 4, 2016 at 10:15 pm
    There are two possible reasons:
    1. You have backface culling turned on (viewport “Options” menu>backface culling). This hides the back faces of polygons; or
    2. Your object is too small for the default viewport clipping setting (Edit>Project Settings>View Clipping). If No. 1 didn’t fix it try setting a smaller clipping distance.
