Activity › Forums › Adobe After Effects › i am trying to add a logo to a 3d football helmet video in after effects
Posted by Matthew Voye on February 10, 2024 at 7:18 pmi am trying to add a logo to a 3d football helmet video in after effects
Graham Quince replied 2 years, 6 months ago 4 Members · 4 Replies -
Andy Kiernan
February 10, 2024 at 7:23 pmYou might have to ask a question, and also give us some more information so we can help you
Reid Vanvoris
February 11, 2024 at 8:11 amhttps://youtu.be/Bce7prKLjD8?si=C9KnmTIJ-DC89eoM
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Reid Vanvoris
February 11, 2024 at 8:12 amAlso see
https://youtu.be/gyf5eZLJi-k?si=DfHtRO77Ny9pWJDd
Graham Quince
February 17, 2024 at 10:31 amHow are you importing the 3D model of the helmet? Is it an OBJ file or GLB file, and you’re using the new AE 3D import? Or are you using Video Copilot Element3D or HeliumX’s Helium, or are you importing into C4D Lite?
In all cases, you need to alter the texture being used for the helmet. With luck there is a separate image file alongside the 3D model and you will alter this in software like Photoshop.
If there is no 3D file, it’s likely the textures are procedural and it gets a little trickier as the solution will depend on the model type and how you’re importing it.
