Activity › Forums › VEGAS Pro › I am rendering staright to in Vegas 11. Where is rendered file being saved?
Posted by Raf Erosa on February 1, 2013 at 7:04 pmVegas 11
Tools> burn to dvdWhen this is rendering, where are the files saved to? I was hoping to avoid re-rendering by pulling up that already rendered file. Is that possible?
John Rofrano replied 13 years, 8 months ago 4 Members · 9 Replies -
Stephen Mann
February 2, 2013 at 3:41 am???
When you go to the “Render As” window, it asks you where to put the rendered files.
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Mike Kujbida
February 2, 2013 at 3:45 amI can’t remember exactly but check the folder locations of your temp directories in both Vegas and DVDA.
The files will be in one of them. -
John Rofrano
February 2, 2013 at 2:44 pm[Raf Erosa] “When this is rendering, where are the files saved to?”
They are saved in a folder called DvdImage under the temp folder that you specified in Options | Preferences | General | Temporary files folder
[Raf Erosa] “I was hoping to avoid re-rendering by pulling up that already rendered file.”
You’d better catch it while it’s burning because once the burn is complete, the folder is deleted and the files are gone.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Raf Erosa
February 2, 2013 at 2:52 pmActually, if you follow the menu options i wrote, Vegas 11 has an option to print to DVD directly. (on my screen it is not active because I didnt put a dvd in the burner, but I use it all the time. Take a look at this menu. My question is specific to this menu option. When It starts the process, it renders prior to burning. I would like to know where does it burn the temp file to?
Stephen Mann
February 2, 2013 at 4:25 pmSorry, I missed the tools>burn in your OP.
But, I’ve never used this option as I prefer to have control over the encoding parameters in the “Render As” menu.Steve Mann
John Rofrano
February 2, 2013 at 5:02 pm[Stephen Mann] “But, I’ve never used this option as I prefer to have control over the encoding parameters in the “Render As” menu.”
Yea, but I believe Raf was looking for a VIDEO_TS folder with VOB files and you can’t get that from “Render As”. It would be nice if Vegas would allow you to specify a folder to save these so that you can burn another DVD copy later.
~jr
John Rofrano
February 2, 2013 at 5:05 pmYou’re welcome. You know you should make a Product Suggestion to specify a folder to save these files so that you can burn another DVD later. I realize that you could just make an ISO of the disc and achieve the same thing but it would be a nice addition.
~jr
