Activity › Forums › Adobe After Effects › I am not able to extend the After Effect comp duration more than 3 hours!!!
  • Walter Soyka
    April 29, 2011 at 7:12 am
    [Sarika Mirchandani] “I am not able to extend the After Effect comp duration more than 3 hours!!! How to break this limit??”
    You can’t. From the help page on Composition settings [link]:
    Note: The limit for composition duration is three hours. You can use footage items longer than three hours, but time after three hours does not display correctly.
    The best I can suggest is to make more than one comp then edit them together in an NLE. But three hours is a seriously long comp…
    Walter Soyka
  • Sarika Mirchandani
    April 29, 2011 at 8:14 am
    Thank you Walter for your suggestion.
    However,I was looking for some kind of script or so for after effect to extend the composition duration past 3 hrs.
    Thanks anyways 🙂
  • Michael Szalapski
    April 29, 2011 at 1:45 pm
    3 hours? Why? If we know the “why” we can help you figure out the best way to work around the limitation.
    Also I certainly hope you’re planning to render an image sequence rather than a video file. I’d hate the render to get to hour 3.5 of a 3.6-hour-long project and fail leaving you with nothing.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Steve Blacker
    April 29, 2011 at 9:16 pm
    I can’t even think of any possible scenario where I’d need a 3 hour comp in AE, to be honest…
    It’s only work if you’d rather be doing something else…
  • Todd Kopriva
    April 30, 2011 at 11:28 am
    You can submit a feature request. Be sure to explain why you would use a single composition greater than three hours.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Tim Kolb
    April 30, 2011 at 6:48 pm
    [Sarika Mirchandani] “I was looking for some kind of script or so for after effect to extend the composition duration past 3 hrs. “
    Um…you may consider using a video editing application instead of a compositing application.
    AE is not really designed to handle documentary-length operations…
    What exactly are you attempting to accomplish?
    TimK,
    Director, Consultant
    Kolb Productions,
    May 2, 2011 at 5:25 am
    Hi all!
    Thanks for taking out time to exclaim on the question i asked 🙂
    But seriously, i personally know about the AE duration limit.However, I was looking out on any script that would allow AE to extend its duration beyond the 3 hours limit.
    Anyways, I obviously broke down my footages into comps and then rendered out through Premiere! The easiest solution 🙂
    Thank you all for your valuable time!!!
    Its highly appreciated!!!
    Regards,
    Sarika.
    May 2, 2011 at 6:04 am
    Hello again!
    The reason to use a single Composition with the length longer than 3 hours is due to the content.
    The content happens to be e-learning which covers a length of 3hrs. + of footage for a single chapter.On the more,I had to render it out as mpeg from AE itself.
    Anyways, I have worked out the solution.
    Again,thanks everyone!!!
