Activity Forums Blackmagic Design HyperDeck studio record light blinking
  • HyperDeck studio record light blinking
    Posted by John Barnes on July 22, 2012 at 4:22 pm
    I have 6 hyperdecks, and one of the decks always has a blinking record light. I have not found anything in the documentation that says what this means. Does anyone know what a blinking record light means, and if there is any adverse effect on the recorded video?
    Chris Pearse replied 14 years, 1 month ago 2 Members · 1 Reply
  • Chris Pearse
    July 23, 2012 at 12:44 am
    Hi John,
    A blinking record light indicates that a frame was dropped and that the recording will have stopped. This will be because the SSD you are recording to cannot keep up with the data rate. If the disk is different to those in the other recorders, that particular model might not be able to write fast enough for the HyperDeck. If it is the same model it’s quite possible that there’s a problem with the disk.
    For more information on SSDs please see the HyperDeck SSD support note.
    Chris Pearse
    Blackmagic Design
