Activity Forums Apple Final Cut Pro Hyperdeck Shuttle files, no sound in FCP X and Qucktime X, but works well in Quicktime 7, meta-tag problem?
  • Hyperdeck Shuttle files, no sound in FCP X and Qucktime X, but works well in Quicktime 7, meta-tag problem?
    Posted by Jonas Bengtsson on October 6, 2011 at 8:32 am
    (Sorry that I double posted but I realized its maybe a FCP X problem)
    Footage taken with Sony V1 >HDMI> Hyperdeck Shuttle.
    FCP X and QuickTime X just plays picturs no sound.
    The file plays perfekt in Quicktime 7 and Soundtrack Pro.
    The files work well also in Quickview, but when i click button “Open with Quicktime”, the same just picture no sound.
    In FCP X
    In info view at right, i only got alternetiv (Video) (Info), no Audio inbetween.
    Info Quicktime 7
    Info Quicktime X
    Jeremy Garchow replied 14 years, 11 months ago 2 Members · 9 Replies
  • 9 Replies
  • Jeremy Garchow
    October 6, 2011 at 5:12 pm
    Is that 16 channels of audio?
  • Jonas Bengtsson
    October 6, 2011 at 8:36 pm
    Yeas!
  • Jeremy Garchow
    October 6, 2011 at 8:51 pm
    That might have something to do with it.
    When you bring it in to FCP and click the “audio” tab of the inspector, what do you see?
  • Jonas Bengtsson
    October 6, 2011 at 9:12 pm
    Nothing.
    The audio tab doesn’t show up at all, only Video and Info
  • Jeremy Garchow
    October 6, 2011 at 11:29 pm
    I would duplicate that file, cut it down to the two or four channels you need and try again.
  • Jonas Bengtsson
    October 7, 2011 at 6:01 am
    Ok!
    My workaround is to bring it up in god old QT 7, extrakt the sound and then make à new compund cliipp.
    But i try the resave the file with QT 7
  • Jeremy Garchow
    October 7, 2011 at 10:39 am
    Did it work?
  • Jonas Bengtsson
    October 8, 2011 at 11:56 am
    Yes it works.
    But extract sound from xxx.mov, resync inside FCP X.
    If it can go wrong it will, and I will end up some files with none sync and the I have to fix that.
    So I rather se it work. But until the bugg is fix I had to take that extra amount with work.
  • Jeremy Garchow
    October 8, 2011 at 2:03 pm
    Just delete the tracks you don’t need and leave the ones you do.
