Activity › Forums › Panasonic Cameras › HVX500: best 23.97 to DV NTSC conversion?
  • HVX500: best 23.97 to DV NTSC conversion?
    Posted by Alan Langdon on November 25, 2008 at 12:36 pm
    I am editing in FCP 6.02, with footage shot using a HVX500 at slow-motion 60fps (23.97 is the frame rate of the footage importred into FCP). Frame size is 960×720.
    Now I need to output to regular DV NTSC, for DVD and DVCam, since the material will go to standard resolution TV (NTSC). So, I exported a native QT Movie from my sequence, preserving all the native settings, so I have a self-contained master. Then I imported this into FCP and placed it into a DV NTSC 4:3 sequence, interlaced, 29.97 fps… regular DV NTSC. Rendered and burned a DVD using Toast 9, which did the conversion to m2v & AC3.
    The resulting DVD shows the inevitable stuttering that comes from the pulldown (24fps becoming 30 fps via duplication of 6 of the 24 frames). I know this is a necessary mathematical comensation, BUT, what is the best way to minimize this artifact? Is tyhere some other route I should be attempting?
    Any info much appreciated!
    Alan Langdon
    Jeremy Garchow replied 17 years, 10 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    November 25, 2008 at 4:09 pm
    For DVD, you can simply make a 23.98 progressive DVD. All necessary 3:2 pulldown will be handled by the DVD player (all DVD players).
    As far as a DV master, you can simply nest your timeline into a 23.98 dv timeline and FCP will add the proper 3:2 pulldown upon play out.
    Make sense?
    Jeremy
  • Alan Langdon
    November 25, 2008 at 5:23 pm
    Great… SOunds almost too good to be true, but I’ll give it a shot.
    So: I need to master to DVCam NTSC, so I should just plug the HD master into a DV 24p timeline and Print to Video?
    I am achieving the pulldown no problem, but it looks jerky when things move horizontally in a linear manner/speed. I have noticed that consumer DVDs (movies, etc) are encoded with a more complex pulldown that includes a interlacing of those repeated frames, which seems to make things smoother… Any info on how to do this sort of pulldown with those repeated frames interlacing?
    thanks for your help!
  • Jeremy Garchow
    November 25, 2008 at 5:40 pm
    [Alan Langdon] “So: I need to master to DVCam NTSC, so I should just plug the HD master into a DV 24p timeline and Print to Video? “
    Yep.
    [Alan Langdon] “I am achieving the pulldown no problem, but it looks jerky when things move horizontally in a linear manner/speed. “
    Ah, but there is a problem. If you put a 23.98 movie in a 29.97 Sd timeline within FCP, proper 3:2 pulldown is not introduced. FCP performs a 2:2:2:4 pulldown. That’s why its imperative to put the footage in a 23.98 dv timeline as FCP will play out the proper 3:2 pulldown.
    [Alan Langdon] “Any info on how to do this sort of pulldown with those repeated frames interlacing? “
    Which repeated frames?
