Activity Forums Panasonic Cameras HVX200 to FCP
  • HVX200 to FCP
    Posted by Tim Vogel on July 16, 2007 at 12:43 pm
    Hi all,
    I tried to capture footage (tape) from my HVX200 and during the scrubbing part of the process to locate in/out points the audio would seem to disintegrate. Cut in and out. If I back the tape up and then forward, sometimes it would fix the problem. Most of the time, if I change the capture presets and then change them back to my original capture settings it would work. And other times yet, if I just FF through the clip it’s ok. It captures everything fine, it’s only during the initial steps of getting the in/out points set up that I have this audio problem.
    Has anyone else experienced this or know what might be happening?
    Thanks for the help!
    –TV
    Tim Vogel replied 19 years, 2 months ago 2 Members · 2 Replies
  • Noah Kadner
    July 16, 2007 at 2:46 pm
    Sounds like your heads might need cleaning or you’re not using quality tapes.
    Noah
    Unlock the secrets of the DVX100 and Final Cut Pro!
    https://www.callboxlive.com
  • Tim Vogel
    July 16, 2007 at 7:02 pm
    Thanks for the response.
    That was my first thought, except the camera is brand new and I am using the recommended Panasonic AY-DVM63PQ tape stocks. Plus the problem cannot be replicated in actual capture. It captures clean, it’s only in playing the tape back searching for in/out points.
    –TV
