Activity Forums Panasonic Cameras hvx200 and xha1; a way to look the same?
  • hvx200 and xha1; a way to look the same?
    Posted by Chris Iuliano on April 10, 2011 at 6:28 am
    So here is my dilemna. I started a project and was using the xha1, but i no longer have use of that camera so I have to shoot the rest with the hvx200. The XH was set to 1080/60i 29.97 fps with a 1/60ss. I figured I could just set the hvx200 to the same settings, only for some reason it won’t let me make the shutter speed 1/60, the lowest it will go 1/100. What im wondering is if i make it 1080/30p 30 fps and 1/60ss will it look the same?
    Noah Kadner replied 15 years, 5 months ago 2 Members · 1 Reply
  • Noah Kadner
    April 10, 2011 at 7:19 pm
    30p and 60i cannot be definition look remotely similar. I’d suggest finding a more common frame rate- such as 60i or 24p. That is if you’re expecting a visual match.
    Noah
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Panasonic GH2 and Canon 7D.
