Activity › Forums › Panasonic Cameras › HVX Output HD and SD signal at the same at????
  • HVX Output HD and SD signal at the same at????
    Posted by Paulo Uchoa on September 1, 2009 at 8:59 pm
    So I need to output from the HVX both 1080i Component signal and 480i Composite at the same time, how do I do this? From what I understand the camera can only output either one or the other but not both, so is there an adapter out there, that can do this simple task?
    -Paulo
    David Williams replied 16 years, 12 months ago 4 Members · 6 Replies
  • Michael Sacci
    September 2, 2009 at 4:12 am
    I’m almost positive that the composite and Y/C ports are always active and of course are always SD, so when the composite is set to HD you should have watch you are wanting.
    Do you have a camera, this would be quick thing to test.
  • Paulo Uchoa
    September 2, 2009 at 5:47 am
    When you have the component plugged in, the composite stops working.
    -Paulo
  • Shane Ross
    September 2, 2009 at 8:47 am
    You can’t do both. Sorry.
    Shane
  • Michael Sacci
    September 2, 2009 at 3:54 pm
    I thought I used both at one time, maybe it was the composite and the Y/C, so much for my memory.
  • Paulo Uchoa
    September 2, 2009 at 6:31 pm
    I understand that you can’t do both. My question is, is there an adapter that can convert 1080i Component to 480i Composite?
    -Paulo
  • David Williams
    October 3, 2009 at 3:41 pm
    Redbyte Decimator
