Activity Forums Panasonic Cameras HVX 200 Viewfinder
  • HVX 200 Viewfinder
    Posted by Lee Berger on June 24, 2006 at 8:44 pm
    I recently shot with this camera and had trouble with the viewfinder. It doesn’t tilt down. I’m 5’8″ tall and have to stand on my tiptoes or a box to look in the viewfinder. A friend says there is a fix in the works, but I can’t seem to find any trace of it on the web. Anyone familiar with it?
    Lee Berger
    Zach Cobb replied 20 years, 2 months ago 5 Members · 6 Replies
  • Deleted User
    June 24, 2006 at 11:13 pm
    [Lee Berger] “I recently shot with this camera and had trouble with the viewfinder. It doesn’t tilt down. I’m 5’8″ tall and have to stand on my tiptoes or a box to look in the viewfinder. …”
    I’m not aware of any “handycam” (non-shoulder mount) camcorder which has a built-in viewfinder which tilts down. There might be an exception, but most don’t. Built-in LCD screens, and external VFs on “pro” cams, can typically tilt up & down, but built-in VFs typically only tilt up.
    As for a “fix”, well I suppose anything’s possible …
    – Peter
  • Lee Berger
    June 25, 2006 at 2:12 am
    Thanks for you response. Actually, one of the first 1/3″, 3 chip DV cameras from Panasonic had a viewfinder that tilted down. It was the AG-EZ1U. It’s probably the exception you referred to.
  • Noah Kadner
    June 25, 2006 at 2:59 am
    Nope there won’t be a fix cuz there’s nothing wrong. Typically if you have the camera mounted far beyond your eye level you either use a monitor, boost yourself up to see the viewfinder or frame up via the LCD display monitor.
    Noah
  • Tony
    June 25, 2006 at 3:36 am
    The fix will be to hire a midget or small children to shoot your stuff.
    Tony Salgado
  • Lee Berger
    June 25, 2006 at 10:22 am
    actually I was thinking more of some stilts that dry wall installers use 🙂
  • Zach Cobb
    June 25, 2006 at 3:16 pm
    Or, as one SFWB to a SWB: High Heel Sneakers!!!
