Activity Forums Panasonic Cameras HVX-200 and Firestore FS-100
  • HVX-200 and Firestore FS-100
    Posted by Mark Maness on August 7, 2006 at 6:45 pm
    Hey gang…
    I’m looking at purchasing this combo to do an extremely small budget feature. I have some question, though… What HD modes can this camera do with this external drive? Is it only 720p or can it do 1080p?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    Stuart Cummings replied 20 years, 1 month ago 8 Members · 10 Replies
  • 10 Replies
  • David S.
    August 7, 2006 at 10:10 pm
    It won’t do any native streams over firewire.
  • Dean Sensui
    August 8, 2006 at 1:33 am
    Wayne…
    It’ll do 1080i and 1080p30 as well as 720p60 and 720p30. Those are the ones I’ve recorded so far. I haven’t tried any other format such 24p.
    Dean Sensui — http://www.HawaiiGoesFishing.com
  • Barry Green
    August 8, 2006 at 3:17 pm
    It’ll record 1080/24p, 1080/24pa, 1080/30p, 1080/60i, and 720/60p, 720/30p, 720/24p with or without variable frame rates. Only restriction is that you’ll have to run the variable-frame-rate footage through a frame extraction utility in order to use it as VFR footage (same process as what you have to do with VariCam footage).
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Mark Maness
    August 8, 2006 at 4:41 pm
    Thank you, Barry…
    That was the answer I was looking for. Doing low budget features can be tough when your budget is extremely low. We have to start somewhere…
    Wayne Carey
    Schazam Productions
  • Marion Laney
    August 8, 2006 at 6:28 pm
    Any thoughts on hard drive sound issues shooting with this config with close miking?
    Marion
    Marion Laney
    Director-DP-sometimes Editor
    ideaWercs, inc.
    Atlanta, Ga. USA
    Producing in HD&35mm&SD
    Food Network series “Good Eats” and others.
  • Stuart Cummings
    August 9, 2006 at 8:16 pm
    Hello Marian,The Firestore fan can make a little noise when it first starts up and when it’s been on for a while (or when its been sitting in direct hot sun for a while). i have the Firestore holster that focus enhancements sells but sometimes the mics can pick up the fairly quite fan on the FS-100. To get around this i have been using the Jimmy Box 2 which was originally designed for use with wireless mics but just happens to fit the FS-100 perfectly. You can check it out Here https://www.jimmybox.com/Hope this helps out. Regards Stuart Cummings Watermark Productions
  • Marion Laney
    August 9, 2006 at 10:25 pm
    Hi Stuart,
    Thanks for the suggestions on sound dampening solutions.
    Marion
    Marion Laney
    ideaWercs, inc.
    Atlanta, Ga. USA
  • Gunleik Groven
    August 11, 2006 at 4:59 am
    Hi! FAntastic!
    Didn’t know you could do VFR with the FS.
    What do you use, when on Mac. XP coud be an option, too..
    Gunleik
  • Christopher Wright
    August 12, 2006 at 6:04 am
    How does the jimmy box help you with sound dampening?? It looks like a nice mount, but I have had the FS-100 cable 6 ft. away from the camera and you still get the fan noise. Is there another piece to the jimmy box that insulates the Firestore??
  • Stuart Cummings
    August 12, 2006 at 6:18 pm
    Hi Christopher, The Jimmy box was originally designed for wireless mics the Firestore just happens to fit perfectly so a lot of shooters have adopted it for use with the Firestore devices. As far as i know there are no additional dampening devices available for it you might email or call Jimmy and see what he has or what are his thoughts are. He is a working DP and originally build the box for himself. The Jimmy box helps move the Firestore away from the camera mics instead of the saddle that Focus sells as an accessory (which positions the Firestore fan directly over the mics). Its worked quite well for me, and i don’t seem to pick the fan noise very often (my fan does not run all the time) Is the Jimmy box the perfect solution probably not but it is a huge improvement over what focus sells. At some point i am sure Focus or someone else will come up with an even better solution in the mean time it is a great wireless mic holder and a decent Firestore bracket! If anyone has come up with a better solution please by all means let us know!! Lets hope the forthcoming and long awaited Cineporter is quieter (since its going to mount directly under the HVX200). For more info about my experience’s with the Firestore and the accessories that i have been using and my use of the Firestore in an underwater housing check out the Sept. issue of Studio Monthly Magazine I’m supposed to be on the cover shooting underwater with the HVX 200 and Firestore.Which is a whole other story!!! Good luck Stuart Cummings Watermark Productions
