Activity › Forums › Panasonic Cameras › HVX 200 and 1200a Question
  • HVX 200 and 1200a Question
    Posted by Barry Dycus on July 19, 2006 at 8:55 pm
    Instead of using my P2 Card to record in HD, Can I use a 1200a deck and firewire to record on set?
    Thanks in advance for any help.
    bd
    Paul Boyer replied 20 years, 2 months ago 3 Members · 3 Replies
  • Chris Bell
    July 20, 2006 at 3:18 am
    Yes, and you can get 1 hour record time. Don’t forget the 1200a has a loud fan, not great for sound shooting.
  • Barry Dycus
    July 20, 2006 at 12:21 pm
    Chris
    Thank you for the response. I do have a few other questions and I hope you can be of some help with them.
    Here is the situation:
    I shoot mainly sports feature/docs with my Varicam and hand off the tape to clients for editing. In August I will be shooting on location with a Varicam on a water sports feature and the client wants to shoot HD in the water. My thoughts were to rent a housing for the HVX200 with 2 8gb cards. Audio will be mastered to the varicam shooting on shore. Because the client will want to walk away with tape at the end of the shoot I thought using a 1200a to dump the P2 cards would do the trick. Now for the questions!
    Do I shoot 24p, 24pa or 24pn when wanting to output to a 1200a for normal film look speed?
    If we decide to shoot off speed both 12 fps(motion blur) and 60fps( for slo motion after frame rate conversion) will this work with my transfer to 1200a idea? I would test the concept but I do not own a 1200a( will be renting for shoot).
    WOW! Hope this is not killing you.
    Any input will be greatly appreciated.
    bd
  • Paul Boyer
    July 23, 2006 at 12:35 am
    We’ve done this a few times, for backup more than to hand tape off, but we shoot standard 720/60p and drop to the 1200 in the field. We’ve done helicopter shots thru the firewire from the 200 into the 1200 and it works, it’s very helpful that the 1200 works on DC. All of the efx that you’ve mentioned work just the same as if we’re shooting varicam. I just read this so I hope it’s not too late.
    All my best, feel free to cantact me if this isn’t clear.
    pb
    zoomroom@aol.com
    HD Production/Post
    Varicam
    1200 Firewire & 1080i cards installed
    All DVCAM & Mini DV
    Pansonic 100a
    sony pd150’s
    Arri srII (16mm) Arri III (35mm) vp’s & other lenses. Time lapse mitchells … all in house
